97 dx tranny noise
Old Jan 17, 2007 | 12:02 AM
knoklu's Avatar
Default 97 dx tranny noise
my 97 makes like a whine/tick noise when ever i go from a high rpm down shift mostly downshifting from second too first and a little from 3rd to 2nd.
i pretty sure it has to do somthing with the clutch, i forgot what that one beairng was called but i want to see what you guys think
thanks
Old Jan 17, 2007 | 10:17 AM
knoklu's Avatar
Default RE: 97 dx tranny noise
i also see to the left under the maintainance light is a little square that turned yellow amonth ago and i thought is was always there till i was driving today and seen it turn red, must have to do with the transmisson, i think the trhowout bearings going out, but stoll need help
Old Jan 17, 2007 | 10:31 AM
cderalow's Avatar
little red square is telling you to change your oil, it's a maintanence reminder, it's designed to be green from 0-5000 miles, yellow from 5000-7500, and red at 7500+ miles since last oil change... most of the time, shops don't reset it, so ignore it if you got a recent oil change and go by the mileage or time since the last change
Old Jan 17, 2007 | 10:38 AM
knoklu's Avatar
yea cause i just had it changed not that long ago.
Old Jan 17, 2007 | 10:39 AM
cderalow's Avatar
you can reset the indicator by taking your key, or another similar shaped object, and depressing the button next to the indicator inward
Old Jan 17, 2007 | 01:04 PM
knoklu's Avatar
thanks, now that i have that prob cleared, im still stressin on that transmisson, is it bad to drive it like that or what.
Old Jan 17, 2007 | 01:15 PM
finalimpact's Avatar
ive only had this problem when the input shaft bearing inside the transmission is going bad.
Old Jan 17, 2007 | 01:17 PM
knoklu's Avatar
is the shaft bearing hard to replace
Old Jan 18, 2007 | 01:04 PM
you have to tear the transmission down to replace it........its not hard if you have a visual diagram or pay close attention to how you take it apart. easiest way to confirm this is by removing the transmission and shacking the input shaft up/down/side to side. any movment means a bad isb
Old Jan 18, 2007 | 02:06 PM
civicblend97's Avatar
an instructer at the college i went to said that body style was know for the bearings in the trans going bad, the only thing he knows is honda so i guess hes right
