HondaCivicForum.com
-   Transmission & Differential (https://www.hondacivicforum.com/forum/transmission-differential-39/)
-   -   advice plz,want awd 6spd tranny in 89 hatch, dont want awd (https://www.hondacivicforum.com/forum/transmission-differential-39/advice-plz-want-awd-6spd-tranny-89-hatch-dont-want-awd-60390/)
civicblend97 Feb 6, 2008 09:07 PM
just want the 6spd tranny i dont care about the awd, i am not going for fast, i want it for the super low first for playin with my car,
ive searched over an over, so things say it will work some things say it wont,
can i buy axles to fit the tranny an the car?
how hard would the shift linkage be?
i know the trans mount may not line up
heres pic of my car so maybe u will understand why i want the trans
if u recomend another tranny plz tell what z6-y8-zc-dx
if anyone knows how much it normally cost to piece a 5spd together with gears from different trannys to get lowest gears that could help
http://i119.photobucket.com/albums/o...7/100_0424.jpg
civicblend97 Feb 6, 2008 09:44 PM
RE: advice plz,want awd 6spd tranny in 89 hatch, dont want awd
also my car is an auto now
Hailchristian Feb 6, 2008 10:04 PM
well..only problem i see is that after the EF's they started with the hydrolic clutches...so you would have to get the new hasport mounts which arn't really cheap....
from what i know all the first gears from the dx, si, zc, hf are all the same......so without a bit of of work i dont know what to tell you.
civicblend97 Feb 6, 2008 10:13 PM
i dont want a hydrolic trans,
an what do i need the mounts for?
i want what ever would give me the lowest gear an will be fairly easy, if it has to be a higher gear for it to be simple then thats what it will get,
finalimpact Feb 8, 2008 02:47 AM
88-91 full time 4wd civic wagovan transmission is 6spd d-series. however i have no idea how you would go about installing this transmission. try ef-honda.com.
My04Civic Feb 8, 2008 04:20 AM
im still trying to figure out what exactly it is
Kommando Feb 12, 2008 01:26 PM
Dude, what are you building that thing for?
Could you just effectively lower the gearing by re-gearing the diff or changing the torque converter?
civicblend97 Feb 15, 2008 05:45 AM
eveyone know this auto civic tranny is not going to hold up to the tires an the off road for long, it already acts stupid trying to change gears, i just need a manual, i may end up putting an si tranny in it, still deciding
civicblend97 Feb 16, 2008 08:27 AM
yes i am gonna do the si tranny, when i get the time an money to do it
