Attention 99-00 Si owners
Old May 18, 2007 | 05:49 AM
Remmy's Avatar
Default Attention 99-00 Si owners
Im curious to know.
When you are cruising on the highway at 70 mph... how many rpms does your tach tell you? If you dont know, run out and try it. I really need to know something STAT.
Old May 18, 2007 | 06:02 AM
ryank327's Avatar
Default RE: Attention 99-00 Si owners
In 4th or 5th gear?
Old May 18, 2007 | 06:18 AM
ryank327's Avatar
5000 in 4th 3900 in 5th
Old May 18, 2007 | 06:45 AM
MY99SI's Avatar
somenhing aroudn that... i havent drivin my car in a long time to give an answer
Old May 18, 2007 | 07:47 AM
Remmy's Avatar
So you all are doing about 4k RPM @ 70 mph in 5th gear right?
Old May 18, 2007 | 08:09 AM
Thats about what Tyler's was doing when I drove it
Old May 18, 2007 | 09:52 AM
Remmy's Avatar
Damn, I was hoping it wasnt the case. You see, when Im cruising at 70mph in 5th, my EGT's go nuts. Honda f***ed up by not making a 6th final gear. I wish there was a 6-speed I could bolt to my motor[&o]. Worse case i just have the final gear switched out.
Old May 18, 2007 | 10:01 AM
ryank327's Avatar
Is a type-R tranny 6 speed? If not the gearing should at least be better suited for more power right?
Old May 18, 2007 | 01:16 PM
2000 Si Newbi's Avatar
Member
ORIGINAL: Remmy
wats that?
Old May 18, 2007 | 01:54 PM
Mr Mobsta Man's Avatar
ORIGINAL: 2000 Si Newbi
ORIGINAL: Remmy
wats that?
Exhaust Gas Temperature.
