automatic tranny problem
Old Jan 6, 2006 | 09:09 AM
ugly86integra's Avatar
Default automatic tranny problem
i have a 91 EX civic with an automatic in it. the problem is that it wont go into rev or 4th before the engine is at normal running temp. it'll go in rev if i put it in neutral and rev it way up and then put it up into rev when it's cold. after it's warmed up it'll go into all the gears just fine. it's not low fluid because that's the first thing i checked! lol i'm into working on everything else on any honda or acura, and i've rebuilt alot of manuals, but i've never been inside a honda automatic! lol if there's any automatic tranny techs in here, i'd sure like to get a lil help!
thanks!
Old Jan 27, 2006 | 07:11 AM
leco516's Avatar
Default RE: automatic tranny problem
Get a chiltons repair guide and locate the modulator. That's a cheap place to start,replace that . also check vacuum hoses on the engine . rpm controls shifting. failing that have a shop diagnose problem. You did change the filter inside the pan, right?
Old Jan 27, 2006 | 09:40 PM
AOL.COM's Avatar
the only thing you can do is change the tranny fluid & hope for the best
Rsporty
Feb 13, 2010 04:22 AM
mpenner
Jun 24, 2008 05:56 PM
speechless33759
Apr 26, 2006 08:50 PM
ugly86integra
Jan 6, 2006 09:09 AM
sandfiretyper
Jun 10, 2004 05:52 PM
