Can I Use Dipstick Hole to Fill ATF?
i would like to change the ATF in my 99 ex.
is there any downside to using the dipstick hole for the ATF to use as a filler hole for the auto trans fluid? |
Originally Posted by sbg20307
(Post 596447)
Thanks. I wasn't sure that the filler hole and the dipstick hole were the same. I assumed there was some square bolt like the drain hole for the filler hole (that I didn't want to find and crack open).
yea use the dipstick hole
the filler bolt method is used for manual transmissions |
so when changing tranny fluid u put it in through the dipstick hole?
Originally Posted by Civic|UnLimiteD
(Post 602253)
and it's the dipstick on the transmission i think there is actually a fill bolt, but it's so much easier to use the dipstck |
