Changing auto to manuel?
i want to get a manuel transmission from the junk yard and swap that with the auto that is currently in my car. i was wondering what is everything that is involved in a tranny swap and how much am i looking for that cost wise? thanks for any info.
RE: Changing auto to manuel?
Pete is doing that same thing in his EG coupe EX we are discussing it HEREcause i am planning on doing the same as well in the future
5spd tranny
shift linkages 5spd starter flywheel clutch and pp cluth pedel assembly clutch master clutch slave cyl master to slave hoses and hard line 5spd ecu(can get away with auto for time being) 5spd swap mount(hasport) or cut upper tranny frame mount and weld in a 5spd unit a little bit of rewiring and your good to go i can usually get the parts for anywhere between 5-800 for a sohc 5spd swap. its not a hard swap to do. takes less than 3 hours to do, at least for me. my first 5spd conversion took all day. |
I wont be doing the labor on mine. I would rather drop it off and pick it up.........Id rather pick up a few extra shifts at work and not have to worry about it.
Come on Pete, man up and do it! LOl:D jk man. I agree.
ORIGINAL: finalimpact 5spd tranny shift linkages 5spd starter flywheel clutch and pp cluth pedel assembly clutch master clutch slave cyl master to slave hoses and hard line 5spd ecu(can get away with auto for time being) 5spd swap mount(hasport) or cut upper tranny frame mount and weld in a 5spd unit a little bit of rewiring and your good to go i can usually get the parts for anywhere between 5-800 for a sohc 5spd swap. its not a hard swap to do. takes less than 3 hours to do, at least for me. my first 5spd conversion took all day. |
ORIGINAL: Kappa22 ORIGINAL: finalimpact 5spd tranny shift linkages 5spd starter flywheel clutch and pp cluth pedel assembly<<<<<<<<<<&l t;<<<<<<<<<<<< <<<<<<<<<<<<pe dal! one not 3 [8D] clutch master clutch slave cyl master to slave hoses and hard line 5spd ecu(can get away with auto for time being) 5spd swap mount(hasport) or cut upper tranny frame mount and weld in a 5spd unit a little bit of rewiring and your good to go i can usually get the parts for anywhere between 5-800 for a sohc 5spd swap. its not a hard swap to do. takes less than 3 hours to do, at least for me. my first 5spd conversion took all day. |
yea but im going to get the manual pedals, either that or see if I can use the sawzall and trim the huge brake pedal down, dont wanna be hitting that when goin for the clutch.........
werd......i just trim them down. ive always hated having to drop the steering colum down to pull the pedals out.
Yeah, I was gonna say... that big-ass brake pedal could be a problem. :D
