Clutch lines?
Old Sep 15, 2007 | 01:43 PM
scottw's Avatar
Default Clutch lines?
Hey, I just bought a 94 civic EX 5 speed.
It was in an accident and now the clutch doesnt work, I believe a line was broken, as the pedal stays to the floor and I believe all of the fluid has leaked out someplace. I was just curious as to if anyone has a diagram which shows the clutch line, especially if any of the lines run to the front of the engine bay, which is where the collision occured.
Thanks a lot
-Scott
Old Sep 15, 2007 | 06:30 PM
civicexracer's Avatar
Default RE: Clutch lines?
best pic i have.
the red is where the clutch bleeder valve is and the yellow is the clutch fluid resevoir. there will be a line or 2 coming from each, those are the clutch lines and probably the ones that would need to be replaced. how bad of an accident was this to crack a line??
Old Sep 16, 2007 | 08:09 AM
scottw's Avatar
Hey, your car in your signature looks just like mine.
Well, a telephone ground wire at 55MPH right at the nose of the car, the hood is a bit bent, and like, the car kinda landed on the wire, and when it ripped out of the ground, the bottom kinda came up, caught the radiator, and pulled the radiator, and everything it's attached too up, so like the crossmemebers are all bent too. And I believe that when all this happened, it ripped that front clutch line bleeder up. I thought that was where it was broken, but I just wanted to make sure. The lines look kinda old and corroded anyway, so I might as well just replace all of them.
Thanks for the picture
~Scott
blatin
Oct 16, 2009 05:52 PM
99ExCivicCoupe
Feb 25, 2007 12:05 AM
burnindesirez02
Nov 26, 2006 06:31 PM
buffman
Dec 4, 2004 03:00 PM
sacicons
Sep 5, 2004 11:02 AM
