clutches
Old Apr 27, 2007 | 09:11 AM
honda_tuner90's Avatar
Default RE: clutches
should i just stay stock??
Old Apr 27, 2007 | 09:24 AM
ryank327's Avatar
Thats up to you. When ym clutch went I decided to jsut replace everything with aftermarket parts. I Put in a exedy Stage one clutch and a Fidanza lightweight flywheel and a new throwout bearing.
Old Apr 27, 2007 | 12:44 PM
how long was instalation?
Old May 1, 2007 | 12:17 PM
johnb's Avatar
are there any clutches out there that make it very easy to take off? i find it hard to take off in my civic. my friend got a new clutch in his focus and its VERY easy to get off to a good start off the line. just curious to know if any of you guys out there with exedy clutches find it easier to take off than with your stock clutch.
Old May 1, 2007 | 10:39 PM
Live_4it's Avatar
Obviously thats the whole point of aftermarket clutches lol. You might loose some power going up hills because of the lighter weight components. And towing force wont be as good depending on the kind you get, (such as 4 people in the carwith groceries in the trunk).
Old May 1, 2007 | 11:30 PM
johnb's Avatar
the thing i dont like about the honda clutches is that there so damn deep. are there any you would recommend that would make it REALLY easy to take off. i mean easier than usual. cuz my friend burnt his clutch out and the replacement one they gave him at his mechanic lets out all gay and its easier to stall then it is to take off so i guess thats what im really worried about.
Old May 3, 2007 | 11:51 PM
justinunger05's Avatar
hey guyss when u go froma stock clucth to a stage 1 clucth what all do u have to change......
Old May 4, 2007 | 08:09 PM
SirusDark84's Avatar
If you geta clutch kit you should get the clutch plate, a pressure plate, and throwout bearing. I would recommend getting a flywheel if you were ever planning on replacing that because thats easy to do at the same time. Also check your pilot bearing.... since thats right on the flywheel too, and replace that if you need to at the same time.
Old May 5, 2007 | 12:09 AM
mybrokenblinker's Avatar
ORIGINAL: Live_4it
WTF? I think there would be less rotating momentum so it would slow down sooner when you let off the gas, but you wouldn't LOSE power.
Old May 9, 2007 | 04:34 PM
2000 Si Newbi's Avatar
Member
ORIGINAL: MY99SI
first off what are your mod's, engine, or plans for down the road?
im using a exedy stage 2 in a 2000 si at about 400whp and i cant launch off the 2-step b/c it starts slipping so im stepping up to a stage 3 or twin plate or maybe a exedy carbon
Always wondered when you say is slipping wat do you mean? Can you feel it and wat does it feel like. I think mine might be doing it too idk.
