Final Drive Ratio Z6 vs. Y8
Old Aug 30, 2006 | 04:17 AM
mentaldis0rder's Avatar
Default Final Drive Ratio Z6 vs. Y8
Ok .. 2 part question... first will a Z6 trans bolt onto the Y7 block??
Also the final drive ration i noticed on Z6 is 4.25 .. vs 3.7 on the Y8 ,, which is better and why? .. Thanks
Old Aug 30, 2006 | 11:47 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: Final Drive Ratio Z6 vs. Y8
z6 tranny will work fine on a y7 block
Old Aug 30, 2006 | 12:55 PM
ef4life's Avatar
the best tranny would be a y8 tranny, they had steel shift forcks instead of aluminum.
Old Aug 30, 2006 | 01:08 PM
Kedawei's Avatar
Y8 is 4.25 also. 1.909 2nd gear as well, as compared to 1.9 for the Z6.
jacobs53
May 5, 2008 04:36 PM
sachmo600
Apr 25, 2008 04:24 PM
Kedawei
Mar 27, 2006 07:26 PM
jcarp613
Jan 25, 2006 02:22 AM
