gear ratio
Old May 7, 2007 | 05:32 PM
SI2000's Avatar
Default gear ratio
what should i do to get more acceleration and less top speed, list any particular brands of parts i should look for. i only need maybe 120mph top speed, i dont need to get that highto runthe quarter.
Old May 8, 2007 | 10:56 AM
SI2000's Avatar
Default RE: gear ratio
no ideas how to do this?
Old May 8, 2007 | 01:12 PM
MY99SI's Avatar
you'de have to spend alot of money on gear sets
why do you want to change your ratios?
Old May 8, 2007 | 03:09 PM
SI2000's Avatar
faster acceleration, i dont need top speed i dont ever go over 120, theres no need to, but i need better acceleration
Old May 8, 2007 | 04:38 PM
MY99SI's Avatar
im sure you can buy a Gear set. but their a couple thousand dollars. what motor ?
Old May 8, 2007 | 05:39 PM
SI2000's Avatar
its a b16a2. im not too worried about the cost because i can get parts at wholesale because i work at a custom shop in WA. i just didnt know where to get it and what to look for.
Old May 10, 2007 | 10:08 AM
red2000Si's Avatar
That might be the worste idea Ive ever heard to improve acceleration. If your top speed is 120 your going to be revving at like 6k on the highway! The b16a2 has an extremely close ratio tranny to begin with why would you ever make it closer? Spend half the money and build the motor or put in a turbo.
Old May 10, 2007 | 10:13 AM
ej6buddy's Avatar
that's a bad idea for a dd. just use the money on something more useful, plus, it won't help you any in the long run, track times as well as et's will suck if you do that (not to mention gas mileage isdown the drain), you'll be changing gears more than giving throttle, so in the end, it doesn't help you at all for your car. invest the time and money into some actual power adders that will help you.
Old May 10, 2007 | 12:40 PM
SI2000's Avatar
i have "actual power adders", as you put it. i wasjust wondering if anybody knew about a better gearing set up. and red2000si dont you mean 2or3times the money on a turbo or building my engine, not half,since i can get trannys for about $500 but i guess i'll do more searching. thanks anyway guys
Old May 10, 2007 | 01:38 PM
ej6buddy's Avatar
ORIGINAL: SI2000
you don't have to be a ***** about it, i was just stating that it's not a good idea, you can do whatever you want, and you'll find out the hard way. you simply have the best gearing for the particular motor you're using. usually, if people go turbo, they usually like to make the gears longer in order to take advantage of the boost range according to spooling time. and even if you can get trannies for cheap, you have to figure the money for the gears, labor, and downtime (which usually isn't a big deal to some people). you can get it if you want, but in the end, you could use the money for piecing together a turbo kit, or work on the suspension. if you're not turboing, then you won't take full advantage of it. you can do what you want though. people might not be that familiar with it because most b/d series trannies have very good gearing, unlike h series and some k series.
