H2B KIT
does anybody know anything about the h2b kit offered for the civic with a h22 setup. because im thinking of either gettin that or just sticking with my tranny and slapping a lsd on it. which would be better?
yes, the h tranny is very sloppy with out of sync gearing, with the b series tranny, the gears are perfect for the powering of the h22. they offer a couple kits from different companies like QSD. some have their ups and downs but all of the kits are basically the same. you can have it done for around 750 i'd say if you shop around. you'll recieve a pretty dam good increase compared to other things you could buy with that money, plus if you plan on staying n/a, then the h2b kit is perfect. the kits come with a few brackets, a slave cylinder extender, and other odds and ends. some modification needs to be done to the chasis as well as the hood because it uses different mounts causing the motor to sit rather high compared to stock. if you decide to do it, you'll have to find a b series tranny, as well as mounts and all axles and shafts with the b series tranny as well as a b series shifter set, so you don't need anything with the h tranny, so that means you can probably go back and sell your h tranny to help with the cost.
