my 99 honda civic ex transmission
Old Nov 3, 2011 | 12:48 PM
bks1962's Avatar
Default my 99 honda civic ex transmission
i have a 99 civic ex.haveing a hard time getting it to go into reverse.
manual trans.it seems that first gear may be starting to do the same.
could it be the cable or is the transmission going out.
Old Nov 4, 2011 | 08:22 AM
droopy128's Avatar
if you move your car a little like in inch or so, starting on second gear, then shift either in 1st or reverse, is it then feel normal?? If it is, then it normal it just need to be align on the gear.
If not, then check you shift rod bushing.
Old Nov 4, 2011 | 12:39 PM
bks1962's Avatar
thank you i will check it out
Old Nov 5, 2011 | 07:53 AM
bks1962's Avatar
Default my 99 honda civic extransmission
went to try what was suggested. only to find my clutch pedal going to the floorbut when i pump it.i can shift gears.but still no pedal.have to pump it continuosley.to get there.need help
Old Nov 6, 2011 | 08:40 AM
droopy128's Avatar
Then most likely it your clutch slave cylinder, change it, and bleed it.
Hondabuyer
Jan 25, 2012 06:45 PM
merky04
Jan 15, 2008 05:59 AM
joekrz
May 8, 2007 11:00 AM
97civic_cb
Aug 17, 2006 12:28 PM
geomac
Jul 16, 2006 08:23 AM
