Replacing CV Axles
Old Jun 7, 2011 | 06:24 PM
Emshey's Avatar
Default Replacing CV Axles
Hello, i have a 1996 Honda civic cx hatchback and i need to do the cv axles/boots on it, i am wondering is it as easy as it looks? taking off the main hub bolt and pulling them off and putting the new ones in than topping up the trans axle with fluid again? i would appreciate any feedback thank you
Old Jun 8, 2011 | 08:16 AM
droopy128's Avatar
Ya, that pretty much it, axle and lower ball joint bolts, a little pry and off it goes..
Old Jun 10, 2011 | 08:26 PM
k98kollector's Avatar
When you are installing the new axles listen for the snap rings to snap into place. Then you know they are properly seated. Don't forget to replace your output shaft seals.
Old Jun 19, 2011 | 09:23 AM
boiler1's Avatar
This shows the process...
https://www.hondacivicforum.com/foru...nt-pics-89313/
There are a few things that can make this job painful, but if you're prepared its not too bad.
fixingacivic
Nov 14, 2008 08:47 PM
S240161
Jul 28, 2005 03:36 PM
93SiHb
Jul 5, 2005 09:47 PM
rzimmer11
Mar 11, 2005 09:39 PM
6thgencupe
May 7, 2004 09:24 AM
