short shifter causing problems?
Old Sep 24, 2005 | 01:40 PM
mill$civic's Avatar
Default short shifter causing problems?
this might be a stupid question..but has anyone heard of a short shifter causing problems? any at all? ..just want to no before i put one on my list to get, thanks team
Old Sep 25, 2005 | 02:26 PM
sacicons's Avatar
Default RE: short shifter causing problems?
the only thing is it *might* hit the exhaust, but usually thats not a problem, and can usually be adjusted. also, it moves the gears faster, so you can grind the hell out of your synchros if you dont speed up your clutch foot to make up for the faster moving shifter. but overall, if youre not an idiot, you can figure it all out, and youll be fine. and youll love having one. oh, and get the polyurethane bushing kit too, that makes as much difference as the shifter itself.
Old Sep 25, 2005 | 07:35 PM
goldfinger's Avatar
Are they hard to install? The bushings and the short shifter..
Old Sep 25, 2005 | 10:31 PM
amg6975's Avatar
ORIGINAL: goldfinger
I just did it this weekend and it was really easy.
Yep, mine sure did hit the exhaust, there's a little counterweight lookin thing in there that I cut off and solved the problem.
Old Sep 25, 2005 | 11:10 PM
StifflersMom's Avatar
Cat Fuсker
Only major problem you might run into would be a made-out-of-crap shifter. Don't buy aluminum ones (I know I have one and it's all good, but you never know).
Old Sep 26, 2005 | 04:08 PM
mill$civic's Avatar
thanks guys, im planning on buying a goodone, no cheap e-bay crap, and ill take your advice and get the polyurethane bushing kit too, and i dont think ill have a problem with grinding the synchros..as long as i no how to shift lol
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
bmxchickie
Oct 5, 2007 06:25 PM
heathershonda
12
May 10, 2007 07:18 AM
ELECTRON BLUE 2000
Apr 18, 2007 11:00 AM
05CivicLX
Jun 4, 2005 12:46 PM
