weird shifting
Old Dec 30, 2006 | 04:36 PM
ic892003's Avatar
Default weird shifting
today while driving too work i noticed my eg was shifting funny, it was sticky while shifting which im sure was do to the cold but then this happened, when i moved the stick out offirst to shift to second gearit came out of 1st gear without putting my foot on the clutch, however to get it into second gear i had to put my foot on the clutch, is this normal and does this mean anhything about my tranny???
Old Dec 30, 2006 | 04:39 PM
Misha's Avatar
Default RE: weird shifting
If you catch the moment it goes pretty easy. I often go from 4-5 to neutral without pressing clutch. The trick isletting off the gas while applying pressure to the shifter, at some moment it just slips to the neutral
Old Dec 30, 2006 | 04:43 PM
ic892003's Avatar
so i guess its normal wut happens, its funny my uncle had a truck that was able yo switch gears without touching the clutch, how is that possible?lol
Old Dec 30, 2006 | 04:47 PM
Misha's Avatar
If you match the speeds of engine and wheels, it will just go in like knife into butter...
Old Dec 30, 2006 | 05:42 PM
ic892003's Avatar
oo is it harmful to the car at all when applying pressure to the shifter without pressing the clutch
Old Dec 30, 2006 | 05:44 PM
Misha's Avatar
Hmmm, I guess it depends on the amount of pressure [8D]
Old Dec 30, 2006 | 05:56 PM
ic892003's Avatar
yea tru, its weird tho wen in first all i hae to too is mingle the stick a little and itll jump into neutral
Old Dec 30, 2006 | 07:07 PM
johnny's Avatar
When i drive my brothers car if i shift at exactly 2200 RPM it goes in with no clutch. In a truck theres no synchros
Old Jan 6, 2007 | 05:44 AM
red2000Si's Avatar
Its called rev matching. If you match the exact given revs your engine will be at in a given gear at a given speed the stick will slide in and out ofgear with no clutch. Just be careful when doing this cuz you can get some pretty sweet grinding out of it if you dont match it up right.
chuzie
Jan 5, 2012 06:49 PM
clownbaby
Aug 31, 2009 02:06 PM
ImportTrendz
May 23, 2007 08:36 PM
Narcoleptic724
Dec 3, 2004 08:58 AM
kobejelbryant8
Jul 15, 2004 08:31 PM
