will swapping the transmission of my car make it run the same as a car with original 5speed tranny?
what you mean? swaping a 5speed with a automatic tranny or swaping a clutch setup?
if your swaping in a automatic..... performance will suck.LOL if swaping from auto to stick it will feel alot quicker!
but your motor will run the same either way.... its just geting the power to the ground that will make it feel differently.
well from a auto to manual it will feel alot beter! and automatic doesnt have theh clutch setup.. it has a torque converter which is the main reason performance blows....
just do your research on it..... ive thought about doing it but thiers just so many little things that im probably beter off just buying a manual car....
but if you can find a donor car go for it!
You need a manual ECU other than that the transmission is simply a torque multiplier, it does not affect engine function what so ever, only engine output.
yeah both transmissions will still have the same engine power so its only thing changing is the fact that you got to shift it yourself.
ORIGINAL: 06coupe
