Worth transmission repair?
Old Jun 20, 2009 | 12:17 PM
Nortsgaf's Avatar
Default Worth transmission repair?
I had a 98 Civic, 2dr with a check light (Transmission) that has been on for 2-3 years. 153,000 on the clock but has been serviced regularly since purchase. I have to put the selector in "2" to pull away then shift into "Drive". I do need a new/rebuilt trans to pass inspection and wanted to know if this would be worth doing. I've been told around $2000-$2500 to fix the problem. How much longer can I expect the engine to last (Roughly) and as it stands what price can I expect for a quick sale and trade in? Thanks for any advice.
Old Jun 21, 2009 | 12:34 AM
i would try to find a used transmission. should be cheaper than rebuilding it or getting a new one. i've heard civic's lasting for about 250k to 300k + with proper maintenance.
Old Jun 21, 2009 | 10:13 AM
jpnolan's Avatar
Never rebuild a civic/teg trans. You can always find one one hondamarketplace.com or cragislist.com or your local junkyard to use. the only reason to have your transmission worked on is to be built for more power.
Old Jun 22, 2009 | 05:04 AM
joukaishou813924's Avatar
automatic trannys wont last as long either, so id rebuild or buy new, buying used will lead you to the same place soon again
Old Jun 22, 2009 | 07:05 AM
WTF automatics wont last as long...... no offense but thats stupid!
just look for a used automatic tranny. if you can do it yourself or find a cheap shop to swap them out then thats cheaper than a rebuild.
http://cgi.ebay.com/ebaymotors/96-00...Q5fAccessories
Clean_Civic_98
Apr 28, 2013 06:39 AM
peterpan00712
Jul 10, 2012 05:56 PM
mpilic
Dec 6, 2004 09:04 AM
balajisv
Jun 14, 2004 11:48 PM
stadler_cj
May 11, 2004 01:55 AM
