Removal of stock radio?
Old 03-19-2005, 09:19 AM
Jeremy102579's Avatar
Default Removal of stock radio?
Need help removing the stock radio out of my 00 ex coupe.
any advice?
Old 03-19-2005, 12:07 PM
Remmy's Avatar
Default RE: Removal of stock radio?
\No problem! Step one... remove the belly pan under the steering wheel, and then proceed to remove the glove box. The belly pan has 3 screws and one clip (which is next to and behind the dimmer controls) and the glove box has 2 screws under it. Remove those 2 screws with the glove box clipped in (or it will fall on your face). The remove the center belly pan. There are 4 screws holding that in. You have to remove the belly pan and glove box in order to remove the center belly pan. Once you remove the screws, gently pull the center belly pan off and unclip the 12v outlet. Then go under the dash of the radio, you will remove two demagnetized screws, once that is done get a puddy knife and a towel, pry out the radio bezel. The whole bezel will come out so dont worry, just unclip the Hazerd lights, AC, and what ever other wire is connected. Now unclip the radio. Your done. When you go to put it back in, keep in mind to check eveything is connected again. The radio bezel snaps right back in with a little palm slam.
Old 03-20-2005, 09:30 PM
D16z6's Avatar
This should be added to the DIY section.
Old 03-20-2005, 11:23 PM
Remmy's Avatar
I should do it with pics shouldnt I? I have to remove my Eclipse radio and slao in a new one soon....
Old 03-21-2005, 01:41 PM
Roost3r's Avatar
dont waste the time..its not that hard..all u need is a screwdriver and a little time
Old 03-21-2005, 02:46 PM
Remmy's Avatar
Thats about it. A screwdriver and a max of 20 minutes of your time.
kdvanstrum@earthlink.net
12-28-2008 08:29 PM
addiction2bass
Interior DIYs
08-09-2008 10:28 PM
Iron_Man_2010
06-02-2008 06:42 AM
germancivic
02-04-2008 11:03 AM
orange12
07-14-2005 01:21 AM
Quick Reply: Removal of stock radio?
