car shuts off at stoplights, idling veeery low
Old 08-28-2006, 05:07 PM
justin's Avatar
Default car shuts off at stoplights, idling veeery low
my 97 civic ex just got new piston rings, and when i got it back from the shop the car shuts off at idle (at stoplights/signs) its embarrasing like i dont know how to drive a manual.. lol. what is wrong?
Old 08-28-2006, 09:06 PM
ryank327's Avatar
Default RE: car shuts off at stoplights, idling veeery low
Is it a manual? Try getting your idle adjusted...
Old 08-31-2006, 10:41 AM
AgentofDarkness's Avatar
Or you could adjust your idle yourself. It isn't too difficult. First goto your engine bay and find the connector for the idle air control and remove it. Next start your engine. Go back to the engine bay and find the throttle body. On the throttle body there should be a screw with nothing connected to this. This screw is to adjust your idle. Turn the screw until the idle speed is where you want it (500-700RPM). Turn the engine off. Connect the idle air control connector start the engine and check to make sure that the idle is correct.
Old 04-26-2008, 09:04 PM
BLaCkSiLo's Avatar
where is this screw exactly on the throttle body? mine idles between ~500-900 given how it feels lol
but it would nice to have it always idle about 900 or so, anything with a paperclip needed here?
Old 04-26-2008, 09:49 PM
If your idle fluctuates from 500-900 rpm when the engine is warm, then before attempting to adjust the idle, you might want to consider cleaning the IACV, bleeding the cooling system of possible trapped air, checking for intake air or vacuum leaks, or doing a Seafoam treatment.
Old 04-27-2008, 09:14 AM
ej6buddy's Avatar
it's either the iacv, vacuum line, or possibly the o2 sensor depending on your current gas mileage.
Old 04-27-2008, 11:02 AM
BLaCkSiLo's Avatar
sorry, it doesnt fluctuate, it idles smooth, i already cleaned the IACV, i meant it usually idles at about 550-600 rpm when warm without lights/ac or any accessories on... i would like it to be about 900 rpms
Old 04-27-2008, 11:33 AM
ej6buddy's Avatar
you would like it to be about 750 considering that's about factory setting without any accessories.
Old 04-28-2008, 09:05 PM
NorthWestPerformance's Avatar
If it started doing it after you got the rings done and not before. I'd say there is something wrong or there is simply a vacuum leak.
hpunder2.0l
08-13-2008 05:01 PM
roblinxs011087
01-28-2008 09:57 AM
NickF829
09-25-2007 12:59 PM
EVL TTWN
04-12-2006 10:20 AM
syedz7
02-04-2006 06:25 AM
Quick Reply: car shuts off at stoplights, idling veeery low
