Are CIVICS hard to make OBD11 SCAN LINKING?
Old 04-21-2016, 10:56 PM
Honder's Avatar
Default Are CIVICS hard to make OBD11 SCAN LINKING?
Just bought a new Cen-Tech 60693 OBD2 Scanner from Harbor Freight. (Same as Autel 419)
I get a "Linking Failure" error when hooked up to my daughter's 06 Civic EX. it runs through all of the protocols but after a minute I get the link failure error. Car will crank but will not start. Scanner works fine on two other cars that I tried.
I am 90% sure that I have a destroyed Mass Air Flow sensor since i got the plug wet and failed to dry it before plugging it back in. Dumb dumb dumb. Is it possible that a bad MAF sensor could cause the linking failure on my new scanner? ( I THINK i may have read that some sensor problem could cause a scanner not to link)
My final question is.... has anyone ever tried to hook up a 06 to 08 Civic to a Harbor Freight (Autel) Scanner? OR do you know of a $100 or less OBD2 scanner that would be able to link and scan with an 06 CIVIC EX?
Thanks for any help you can offer
P.S. I read that some car manufacturers make it hard for certain models to be scanned so that car will be brought to dealer of qualified tech. Does Civic have this reputation?
silver2000civic
03-05-2010 06:23 PM
iheartmyhonda
09-24-2006 04:21 PM
triggerstep
01-19-2005 07:46 PM
mxpunk409
12-05-2004 05:06 PM
dalifts
09-21-2004 12:22 AM
Quick Reply: Are CIVICS hard to make OBD11 SCAN LINKING?
