EGR location 98 civic HX
Old 07-02-2006, 05:42 PM
nfrost's Avatar
Default EGR location 98 civic HX
Does any one have the location of the EGR on the D16Y5 engine, I'm getting a trouble code with on enough flow but I can't even find the EGR to check in on the code
TIA
Cheers
Nathan
Old 07-07-2006, 01:30 PM
jwsimons's Avatar
Default RE: EGR location 98 civic HX
do you have an auto tranny??? if not, you have no egr..
Old 07-09-2006, 09:25 PM
nfrost's Avatar
It's a 5 speed, I keep getting a engone code sendingme to the egr PO401 any other options to repair this one since there is no EGR
Thanks for the reply
Nathan
Old 07-09-2006, 09:33 PM
riceburner700's Avatar
if you have an egr valve it will be inbetween the throttle body and valve cover, looks like a gold canister
Old 07-21-2006, 11:50 AM
It's actually a black bodied cylinder on my 98 HX, on the left-hand side of the intake manifold, and attaches with two nuts onto permanent bolt ends. It has an electrical harness connector on top and mine says Siemens EE01 0914C. Yours may be different. I've gotten a replacement gasket and have been cleaning mine out with carb cleaner. I'd kinda like to clean out the chamber, too, but I figured out you need another gasket for that, and I'm not sure about removing the injector rail (or whatever it's called). I have both the 96-98 and 96-00 manuals and neither one gives any specifics on cleaning. Evidently some accords had service bulletins regarding clogged EGR ports.
Old 10-28-2013, 11:51 AM
hakachukai's Avatar
I'm trying to check out the EGR system on my 98 Civic LX 1.6L Engine. It's a 5 speed manual tranny.
I can't find the EGR valve for the life of me! I'm not having any trouble codes, I just wanted to make sure that it was working properly before I get it inspected for emissions.
I can't find any EGR valve
I can't find any place for it to connect to the Exhaust OR Intake manifold
I can't find any wires or hoses for it
I also checked connection A-7 at the ECU for the pink EGR valve control wire. It's not there. It looks like it never was there.
My FSM says that it should be there ( even for a manual tranny )... but I can't find any evidence of it :-(
Is it possible that some of these cars really don't have EGR valves?
Old 10-29-2013, 06:48 AM
This is a 7 year old thread. Have you done searches on google images?
https://www.google.com/search?q=98+C...w=1366&bih=683
Old 10-29-2013, 09:17 AM
The 98 Civic LX lacks an EGR system. Only the 96-00 Civic HX has an EGR system.
mushi
08-20-2010 05:48 PM
fattony
06-03-2009 08:48 PM
asechrist
05-24-2008 07:53 PM
paristscp
11-19-2007 09:08 PM
superfestiva
13
05-26-2006 04:20 PM
Quick Reply: EGR location 98 civic HX
