Cylinder 2 not firing
Old 10-19-2011, 04:08 PM
srdaniel's Avatar
Default Cylinder 2 not firing
So after replacing the all metal head gasket, cylinder 2 is not firing. I swap plugs and wires and I'm only running on 3 cylinders.
Pressure testing, I'm getting 180, 150, 170, 180 psi in each cylinder. I'm thinking it's either the distributor or cylinder 2 is getting tons of oil in it. Pulling the plug on cylinder 2 I'm getting spark just as bright on the other cylinders.
I'd rather not spend money on a distributor without knowing that's the problem. Any thoughts?
Old 10-20-2011, 05:27 AM
srdaniel's Avatar
Whats the best way to see if fuel is getting into a cylinder?
Old 11-08-2011, 09:02 PM
srdaniel's Avatar
Turned out it was a bad fuel injector on cylinder #2. I took the old one out, put a couple of drops of sea foam in the top, hooked it to 12v and it didn't. Two other injectors tested the same way worked fine. One thing to note, 18 year old fuel injectors require, I mean require new o-rings. The old ones lasted 45 seconds before squirting gas everywhere. The new o-rings work much, much better.
mabus013
04-01-2023 04:19 PM
CathleenStargazer
12-14-2013 05:10 AM
cjy01
10-15-2011 10:08 PM
jusplayn85
12
03-12-2006 09:39 AM
cdubscivic
06-20-2004 06:10 PM
Quick Reply: Cylinder 2 not firing
