94 Civic Sunroof Drain tubes
Old 08-21-2011, 10:23 AM
freshane's Avatar
Default 94 Civic Sunroof Drain tubes
Hi, recently found the cause of a leak under my driver side dash. Kept thinking it was the door seal but after fixing that it kept getting wet a little bit. Washing the car it wouldn't show but today I kept filling up my sunroof drain tube that goes down the front driver side and found that it takes quite a bit of water for it to show up. I've been reading ways to unclog this and seems like air compressor is the easiest method. Only thing is water is draining out behind the front tire fine so it might only be partially clogged. I think I read that there is a Y connection in there and can leak out the Y connector or somewhere else. Where does that other hose go to and is there anyway to access that Y connection?? I think I a drain hose way up under the dash but not sure how to access that. Thats definately where the water is coming from and it runs down where the Hood Release is. Whats the best way to fix this?? Thanks for any help
tnicol01
01-29-2008 04:20 PM
Strong Island
12-23-2007 09:51 AM
talford
04-07-2007 07:29 PM
C Dub
01-11-2007 07:30 PM
R35P3KT
08-03-2006 12:31 AM
Quick Reply: 94 Civic Sunroof Drain tubes
