95 Civic ex
Old 06-10-2010, 05:37 PM
www.hondatech,info, click Civic when you see it. Its on there somewhere.
Old 06-15-2010, 04:57 PM
StonedCold's Avatar
Ok, popped the valve cover off, and timing belt cover. Looks like a newish-if not new- belt.
Something won't turn. Where should I start?
Tearing it apart and start there? or check make sure belt is right?
If belt isn't right would it cause it not to crank/turn?
If I want to take head off in car- what all do I have to take off?
Old 06-16-2010, 03:40 AM
tstephens4's Avatar
This coming from a newbie, but did you try to remove the spark plugs and crank it? I know that you said it wasn't hydro locked but it sure sounds like it is. Or something is seized and the problem is far greater.
Old 06-16-2010, 07:49 PM
StonedCold's Avatar
problem is far greater.......
Old 06-17-2010, 04:45 AM
tstephens4's Avatar
D@mn. That sucks. Well, it sounds like you have another Civic that can take you places so that is a good thing. I think you have 2 options.
Option A - Its a civic...HUGE after market. Rebuild engine or better yet replace with a DOHC vtec, or even SOHC vtec (sorry guys i am a newb and do not know engine codes yet) OR try to get parts from a junkyard just to make it run.
Option B - Sell it. Since it is a civic witha huge after market i am sure someone would take the body and do option A themselves.
Good luck man.
Old 06-17-2010, 12:56 PM
shatteredsoul76's Avatar
Silly question but are you sure the starter isnt causing the engine not to turn at all. Squirt a tad of oil inside each cylinder and turn the engine over with a breaker bar, it may just break loose.
Old 06-18-2010, 04:39 AM
tstephens4's Avatar
That could be a great solution and at this point worth a try.
Old 06-22-2010, 05:25 AM
StonedCold's Avatar
Working on it some today.updates will follow.....
Old 06-22-2010, 03:47 PM
StonedCold's Avatar
Found the problem. Broken piston rod. Hole in side of motor. Had to take stuff apart to find it.
So I'm now in the market for a motor. kind of better this way. I'll be able to clean it, and replace the clutch while it is OUT of car....
Old 06-23-2010, 08:33 AM
tstephens4's Avatar
That will do it, every time ha.
