Any tips for removing this difficult fuel filter?
Old 05-20-2009, 04:30 PM
inthezoneac's Avatar
Default fuel filter leaking from bottom nut!
ok thanks, got it off
however, i put on the new filter and the bottom nut area leaks. Try old filter, still leaks. No washer goes on the bottom area, but that's where it's leaking.
Old 05-20-2009, 05:06 PM
There's a simple trick. I think there's a 19mm nut at the base of the filter. Use a 19mm wrench and 14mm wrench in a scissor-like configuration to break the 14mm nut loose with a squeezing action.
Old 05-20-2009, 05:58 PM
Old 05-20-2009, 06:02 PM
The nut is probably not quite tight enough. Use the scissor-like action again but with the wrenches reversed to get the nut tighter.
Old 05-20-2009, 06:51 PM
I'll mess with it again tomorrow, I tightened it a little more where it's about 99% leak free lol
I hate working on my car and then some bs happens, makes me want to never work on it again.
Old 05-22-2009, 09:01 AM
RAVIE's Avatar
try a new washer fyi on the bottom of the filter there is two washer if i can remember one washer goes on the nut you insert it in the line and then another washer goes after then you screw it on the filter
tomp
04-12-2011 11:42 AM
black95coupe
01-28-2010 04:53 AM
Hailchristian
06-23-2008 12:49 AM
pusha1031
11-06-2007 07:41 PM
seriously_furious
08-14-2006 08:49 PM
Quick Reply: Any tips for removing this difficult fuel filter?
