auto to manuael swap
RE: auto to manuael swap
Well ur gona need alot of parts best thing will be ebay or junkyard, ur gona need the the 3rd pedal which is the clutch pedal, need the master slave cylinder, the clutch lines ,the manual d16y8 or b16a2 engine harness that way u dont have a problem with the reveser light u could still use the automactic gauge cluster and i almost forgot the shift links
well i called Hmotor's and this is what it comes with
Motor
Hydraulic Tranny
P30 ecu
axel's with halfshaft
Stock mounts
alternator
starter
Clutch
flywheel
Intake manifold
Exhaust manifold
Fuel rail
Injectors
Dizzy
Engine harness
all sensor's
and they will add pedal assembaly.
what about LSD do i need it or will i be fine w/out it for now? anything else i am missing?? Im pretty new to this. and for that it will $3,000.00 shipped.
Motor
Hydraulic Tranny
P30 ecu
Stock mounts
alternator
starter
Clutch
flywheel
Intake manifold
Exhaust manifold
Fuel rail
Injectors
Dizzy
Engine harness
all sensor's
They're sending a "hydraulic tranny?" Wouldn't that be an automatic? Also make sure you're getting the manual ECU. You will still need to find the shifter linkage, clutch lines and possibly cylinders yourself.
tranny( s41, y21) ???? but what they told me 5mins ago is that it comes with clutch lines, 5speed tranny,p30 manual ecu, shift linkage etc. and what they told me (in a smartass way) uhh.yes it come with all of that cuz that is part of the engine..
So..lol i mean it is a "complete" change over i comes with everything i need to make it a 5speed. i hope
YEA U CAN USE THE P30 ONLY IF UR GONA GO STOCK FOR NOW CUZ IF U PLAN ON ADDING POWER JUST GET THE P72 CHIPPED AND THE CONVERSTION HARNESS THAT GOES OBD2 TO OBD1 BUT IF UR GONA PAY 3000 GRAND FOR A CHANGE OVER THEN U DONT HAVE TO WORRY ABOUTITEVERYTHING SHOULD COME WITH IT IF NOT, I WOULDNT PAY THAT MUCH AND NOT HAVE IT COMPLETE
yea, if it wasnt the complete swap then i would never pay 3grond for it. but since the motor comes as a complete change over for 3grand then it has to have everything included. but it will be stock for now. untile next year or so then i might boost it. for like 250whp and atleast 190-200wtq well..something with in that power range.lol but what about the LSD? do i need that or can i wait on it? for now..
