Bent Crossmember? Need Advice
Hi, I have a 98 Civic DX that thanks to my not paying attention I ran over a parking block. From what I can tell I bent the front crossmember that supports the radiator and two cooling fans. The radiator and fans were bent backwards and cracked. It also put a big dent in the oil pan. Can anyone tell me if it is possible to bend it back into shape and if so how would I do it. I want to try to fix this myself. Thanks
I dont know if it can be fix, but here are some links to the parts.
radiator supports
http://motors.shop.ebay.com/_Car-Tru...eZHonda42abae4
crossmember
http://cgi.ebay.com/ebaymotors/96-Ho...Q5fAccessories
radiator supports
crossmember
There two different pieces. what i understand that your saying is you bent 2 things your crossmember, and your radiator support. If im correct a crossmember has nothing to do with the radiator. Im not to shore if these parts are welded. If your radiator/fans are puch back it sounds like you also need A NEW radiator support.
you posted this in the wrong place(General Tech Help is where it should be) , but some one should be in here that knows more than me soon...
theRDRman
12-13-2011 09:52 AM
staffordgt
02-18-2009 03:05 PM
