Better MPG Help
Old 11-02-2009, 07:51 PM
hamorhead's Avatar
replace plugs wires and dizzy cap
as well as air filter and change oil
if your serious about mpgs visit cleanmpg.com and ecomodder.com
Old 11-06-2009, 09:58 PM
^ well good for you, delete the funiture ad in your sig and you will get even better gas mileage!
Old 11-07-2009, 07:39 AM
joespaghettio621's Avatar
thanks alot everyone. i got a lot of good ideas.
Old 11-11-2009, 06:08 AM
vol245's Avatar
Default Air in tires
Keep the tires inflated to 32 psi. The rest of the stuff is garbage. You will never get the money back from an exhaust or any intake with fuel savings. At best you would get 1 mpg.
Drive it gently and if you see a red light ahead coast up to it (and don't hold the clutch in while you are doing that like someone else mentioned), keep it tuned up and keep the tires inflated. Under inflated tires will hurt mpg. Try riding a bicycle with under inflated tires and you will get an idea how much harder the car has to work when it has them.
Old 11-11-2009, 08:42 AM
wow. ok thanks. one thing tho...i have 2 different sets of tires. 2 have a max psi of 51 and the other 2 max 40. how should I keep these inflated?
Old 11-11-2009, 09:16 AM
go by what the sticker on your car says, i believe its 32 in front and 30 in the back
the sticker is located in the door jam
98LX150
03-12-2008 08:56 AM
gramfam
17
06-04-2007 10:22 AM
05CivicLX
02-17-2007 06:01 PM
84runner
08-01-2006 11:30 PM
NickF829
07-05-2006 01:14 PM
Quick Reply: Better MPG Help
