Brake lights
Brake lights
does anyone know if it is possible to make it so that my brake lights are the same as in a Sedan?? for example if you look in my sig for a reference picture.. when i brake the outer two lights, lights up and the inner two do nothing.. now on a sedan of the same model all 4 lights get lit.... and if this is possible.. would it be hard to do??
RE: Brake lights
I don't suppose it would be too painstaking if you're into wiring. I believe this would be exactly like when I wired my reflector bar lights to shine with the 3rd brake light. All I did was upgrade the 3rd brake light wiring harness and split it from there, running a hot and ground wire to the decklid. I had to drill out a hole to put my lights in though, I'm not sure if you will need to do that.
With just the parking lights on ^
Brake pressed ^
Daytime ^
And this is how they normally are....
(Sorry, couldn't find another pic of when my car was stock)
Brake pressed ^
Daytime ^
gmanjase
11-06-2013 10:33 PM
itzcorky
09-21-2011 07:45 AM
Cosworth
12-15-2008 05:35 AM
j2performance
01-15-2008 01:48 PM
