compression test
Old 07-11-2007, 09:17 AM
Default RE: compression test
That engine is tight! No need to mess with the pistons or rings.
Old 07-11-2007, 09:56 AM
noshowallgo's Avatar
ok cool then il just do the other things cuz i didnt feel like changing the pistons and rings lol
Old 07-11-2007, 09:50 PM
AgentofDarkness's Avatar
If I was going to drop $600 on a motor, I would replace pistons and rings first. You can pick up pistons/rods/rings for a little over $600. If you can't do your own labor, that is going to kill you. I think you will make much better power with a piston/rod upgrade than with a cam and valve spring upgrade.
Old 07-12-2007, 12:17 PM
ok yeah i can do the labor im sure i will get pissed at times but anyway so i sould change the pistons/ rings /rods im looking to get around 230-250whp
Old 07-12-2007, 03:02 PM
get your camshaft after you turbo the car. N/A cams and turbo cams are different, so your car won't be running to its full potential if you have a N/A cam in a turboed car.
Old 07-12-2007, 05:18 PM
ok i will
Skrapdoggydog
01-16-2007 01:14 PM
b8teen
17
12-19-2006 06:17 PM
01CivicEX
08-30-2006 11:05 AM
Meta
08-10-2006 01:46 AM
chones2083
06-02-2005 06:48 PM
Quick Reply: compression test
