engine oil pressure source
Old 04-08-2008, 04:12 PM
cvpi46's Avatar
Default engine oil pressure source
I gotta know where i can find a source of engine oil pressure either via pipe plug or oil pressure sending unit. the car is a 1996 civic with a 1.6 liter vtech
Old 04-13-2008, 06:48 PM
TheJGB3's Avatar
Default RE: engine oil pressure source
I am assuming that you want to install an Oil pressure gauge?I wouldget a "sandwich adapter" from glowshift gauges. This adapter screws on where your oil filter goes and then you screw the oil filter onto it. It has 4 threaded holes for gauge senders and comes with plugs for the holes that you don't use.
Check out their site at:
http://www.glowshiftdirect.com/index...mp;Category=37
Old 04-13-2008, 09:13 PM
lcn584's Avatar
i have that glowshift adapter installed on my 93 civic. its a very clean install and its plug and play. its just that it gets the reading before the filter so whenever you switch the ignition to "on" without the engine running yet, there will be a 20 psi (approx) reading on your gauge becuase of the pressure in the filter...i think.
even when i used to have my sender unit installed on the original sensor port (on top of the filter) using brass "t" fittings, it had a reading too, albeit lesser at around 10 psi. i understand that fron this port, most of the oil gets extracted after you shut down. whilst in the filter, there is always oil remaining in it.
lunger
07-10-2011 02:50 PM
oilltd
06-10-2008 04:06 PM
phan10m
07-07-2007 04:27 PM
FlipHKD720
04-27-2007 04:35 PM
Quick Reply: engine oil pressure source
