hel phelp help help help!!!! =(
Old 12-12-2009, 05:39 AM
Pull the CEL codes, that will be a big help and when the CEL came on your VTEC is shut down until the CEL is removed..... so could the no vtec be your "lag"?
Old 12-12-2009, 11:43 AM
Willby24's Avatar
D16Y8's are known to have oil problems. It is possible you damaged the lower end if you were missing 2 quarts of oil. I experienced a similar issue with my y8. I was cruising down the highway and lost all power, turns out I spun two rod bearings and bent a rod. Prior to my mishap I thought I had a bad valve tick, but I actually had a rod knock.
Definitely pull the codes and go from there.
Old 12-12-2009, 01:32 PM
MBrent's Avatar
July 2010 ROTM
spun rod bearing = good time to swap in a b series. sorry bro, u may be effed. why would it be 2qts low man? any idea? did u change the oil last or did u get it changed? and why would u rev ur car to 7k? its not making any more power @ 7 than it would @ like 6250...
Old 12-12-2009, 02:55 PM
MBrent's Avatar
July 2010 ROTM
ive never heard of transmission drum. is the engine clicking, or knocking? does it sound like its about to come apart?
Old 12-12-2009, 06:14 PM
Pull your CEL code(s). Read here: http://www.honda-tech.com/showthread.php?t=1901557
Post results.
Quick Reply: hel phelp help help help!!!! =(
