noob question!!!
Old 08-31-2014, 05:45 PM
Arcangelwarrior's Avatar
Question noob question!!!
What kind of oil should I use in my Civic? I have a Civic 2000 LX with over 1250.000 miles. I have seen people using 5-30 or 5-20 but some others use 10-30 or 10-40. Also, should I use regular oil, blend synthetic or Synthetic?
Old 08-31-2014, 08:02 PM
itburnswhenIP's Avatar
put it this way honda spent millions designing your engine if they say use 5w20 then use 5w20 and don't listen to anybodys personal opinion. i prefer moboile1 full synthetic 5w20 but thats my personal opinion.
Old 09-01-2014, 12:04 AM
Live_4it's Avatar
https://www.hondacivicforum.com/foru...oil-faq-69106/
My recommendation is to switch over to full synthetic.. or atleast a good high mileage blend. If you have been using conventional and want to switch to synthetic just do this. Use seafoam or other engine oil cleaner. Run for 500 miles, drain and fill synthetic. Drive for a few thousand miles or so and monitor for leaks and oil consumption. If only moderate (which is normal for older Honda engines) no big deal. If it's going through a quart every couple weeks or more, switch to high mileage blend or conventional. Drain and fill again you will notice a bunch of sludge cycling out of your engine still, it is remnants from conventional that is normal. Then should be good to go for regular oil intervals.
Drdslove
06-03-2009 08:12 PM
THE_CRIPPLER
09-23-2005 02:18 AM
farfrumugen
EG Swaps
08-30-2005 10:40 PM
V
07-29-2005 01:48 PM
carlover
07-24-2005 09:40 PM
Quick Reply: noob question!!!
