opnion on trans
Old 08-16-2010, 05:27 AM
link32183's Avatar
Default opnion on trans
Okay, I have decided not to go crazy with the motor (no turbo) so here is my situation. trans is shifting like s**t 1-2, 2-3 and some times off the line it has motor hop. I work for a mechanic shop (im not a mechanic long long story) so i have the resources and manpower/knowledge available.
so my question is should I rebuild my existing trans or buy a new one?
motor mounts I will do at the time when i swap/fix the trans that should fix the hop and make it run a bit smother, also is converting it to stick worth it? i like stick but not sure its worth the time/effort, its not like im racing this thing.
Old 08-16-2010, 05:34 AM
KingDakota12's Avatar
See IMO I honestly would never try to rebuild a Tranny, but at the same time im not the best with car's and would have to do many DIY's and so on. So I would end up spending the money on a quality item.
Old 08-16-2010, 10:44 AM
If you work for a shop and you've got people around you who know what they're doing, i'd say fix it if the transmission is otherwise in good shape. I would also replace your input shaft bearing while you're in there, since those love to go bad in our transmissions. But yea, sounds like you're gonna need to replace a couple syncros
tman07
04-23-2008 01:53 PM
yetti8
10-01-2007 10:26 AM
bonzitre
01-21-2007 08:51 PM
Lordnismo
09-26-2006 03:07 AM
jtshop
09-08-2004 06:01 PM
Quick Reply: opnion on trans
