Problem?
Alright.
Here's one from an LX. The only difference is that it has a tachometer. The redline is correct, as the LX and DX share the same engine.
It will all plug and play. If you want to retain the correct odometer reading it would be best to swap the speedometer gauge from your old cluster into this one. The odometer can be rolled back but swapping them is more simple. Basically, once you remove the gauge cluster you take it apart (which I assume you know how to do since it seems you somehow accessed the needle and broke it). Then on the back of the gauge cluster are 4 screws in a square pattern behind the speedometer. Those hold the speedometer into the cluster.
http://cgi.ebay.com/ebaymotors/92-93...#ht_500wt_1182
http://cgi.ebay.com/ebaymotors/92-95...#ht_500wt_1182
if the tachometer does not concern you, here is a DX cluster (the only one I could find that wasn't in auction format)
http://cgi.ebay.com/ebaymotors/92-95...s#ht_500wt_956
Slammed98silvercoupe
14
12-19-2010 05:16 PM
djt
06-21-2008 07:48 AM
redlines4us
08-22-2006 05:49 AM
tanksOnFire
01-08-2005 03:38 PM
tanksOnFire
01-08-2005 03:38 PM
