True VTEC
Old 04-05-2009, 10:56 PM
lement92's Avatar
Default True VTEC
i have a 2002 ex. how would i go about getting a true VTEC as opposed to iVTEC?
Old 04-06-2009, 01:54 AM
TheJGB3's Avatar
IIRC iVTEC (intelligent VTEC) is the only available VTEC for those years.
Old 04-06-2009, 05:30 AM
I have a 2002 EX and I'm now wondering what's the difference between iVTEC and VTEC?
Old 04-06-2009, 05:43 AM
mudferret's Avatar
Here's what Wikipedia says about iVTEC.
Originally Posted by Sir Wiki
i-VTEC (intelligent-VTEC)[4] introduced continuously variable camshaft phasing on the intake cam of DOHC VTEC engines. The technology first appeared on Honda's K-series four cylinder engine family in 2001 (2002 in the U.S.). Valve lift and duration are still limited to distinct low- and high-RPM profiles, but the intake camshaft is now capable of advancing between 25 and 50 degrees (depending upon engine configuration) during operation. Phase changes are implemented by a computer controlled, oil driven adjustable cam gear. Phasing is determined by a combination of engine load and rpm, ranging from fully retarded at idle to maximum advance at full throttle and low rpm. The effect is further optimization of torque output, especially at low and midrange RPM.
The K-Series motors have two different types of i-VTEC systems implemented. The first is for the performance motors like in the RSX Type S or the TSX and the other is for economy motors found in the CR-V or Accord. The performance i-VTEC system is basically the same as the DOHC VTEC system of the B16A's, both intake and exhaust have 3 cam lobes per cylinder. However the valvetrain has the added benefit of roller rockers and continuously variable intake cam timing. The economy i-VTEC is more like the SOHC VTEC-E in that the intake cam has only two lobes, one very small and one larger, as well as no VTEC on the exhaust cam. The two types of motor are easily distinguishable by the factory rated power output: the performance motors make around 200 hp (150 kW) or more in stock form and the economy motors do not make much more than 160 hp (120 kW) from the factory.
In 2004, Honda introduced an i-VTEC V6 (an update of the J-series), but in this case, i-VTEC had nothing to do with cam phasing. Instead, i-VTEC referred to Honda's cylinder deactivation technology which closes the valves on one bank of (3) cylinders during light load and low speed (below 80 km/h) operation. The technology was originally introduced to the US on the Honda Odyssey minivan, and can now be found on the Honda Accord Hybrid, the 2006 Honda Pilot, and the 2008 Honda Accord.
Old 04-06-2009, 11:25 AM
Thanks for the info, it gives me a better idea about what's going on under the hood.
-Sybmi
Booger
EK Swaps
08-09-2011 10:11 PM
BuckHijo
05-06-2008 03:22 PM
dalifts
12-05-2004 05:13 PM
D16z6
08-19-2004 06:44 PM
baker7598
06-10-2004 09:33 AM
Quick Reply: True VTEC
