2001 Civic Ex 5 Speed Won't Turn Over
Old 11-12-2014, 07:48 AM
HMCretired's Avatar
Unhappy 2001 Civic Ex 5 Speed Won't Turn Over
2001 Civic was running great, put the key in and nothing.... not being a mechanic I did the following:
Checked Battery: Good
Changed Starter: New
Checked Fuses: Good
Checked Clutch Sensor: Good
Replaced Ignition Switch: New
Still will not start when you turn switch on, will run great with a push and a clutch start it. All lights come on, kind of a humming sound coming from back side of the glove box.
Please advise, need help on this one.
Old 11-12-2014, 04:09 PM
Try jumping the starter by using a test wire from battery + to the small terminal on the starter. The engine should turn, so make sure it is in neutral with the brake set. This will determine that the battery, starter, and connections between them are really OK.
Old 11-12-2014, 06:58 PM
itburnswhenIP's Avatar
have you hooked up a scan tool cuz im guessing its ECU related.
Rwb003
08-11-2013 06:51 AM
thedmanhere
14
07-06-2011 12:12 PM
joelmatt89
01-15-2009 08:41 PM
simonx420
05-29-2007 12:33 PM
Corksil
16
01-10-2007 08:55 PM
Quick Reply: 2001 Civic Ex 5 Speed Won't Turn Over
