Sponsored by:
Sponsored by:
2002 Honda Civic noise just happened today
Old 06-22-2014, 08:39 PM
Lataya Dingo's Avatar
Default 2002 Honda Civic noise just happened today
Hi folks, thank you very much for helping me out.
I believe the squeaky noise is from belt, but I am not sure. I post the ticking/chirping noise here:
https://www.youtube.com/watch?v=i5w0VwxOxQg
it's Honda civic 2002, first time owner, 98k miles. no parts change under
hood.
yesterday I notice the AC doesn't function well, seems like doesn't work.
Besides that, everything work fine.
today it's 75 degree. I drove 30 miles on highway, turn on maximum AC even
though there is no cold air coming out. I notice it's hard to drive beyond
60mph, and maximum I can reach to is 70 mph. I also notice the "woooo" noise
from under hood. I thought it's strange, but didn't pay much attention.
I got to local doing some shopping, 15 minutes late, I start the engine (didn't give it some gas ) . I
heard this roaring noise which scare me. i hurry back home. On the way back,
I turn off AC, the noise apparently reduce a lot, and I can also drive to
80mph easily.
Once I got home, I let engine idle , and record this video. the noise is not
roaring but still noticeable. It seem to under the runing belt, or under the
engine.
Any thoughts?
Old 06-23-2014, 04:01 PM
itburnswhenIP's Avatar
it could be your water pump since it appeared to get louder when you moved towards the water pump. your car is past due for a new water pump,timing belt and drive belts. if your timing belt snaps say goodbye to your engine. also im guessing that your ac compressor clutch is seized up that's probably what you heard screeching. it looks like a ton of rust to maybe you bought a flood car does it smell moldy musky inside the car ???
Old 06-23-2014, 04:23 PM
Take the A/C belt off and spin the compressor pulley by hand. Any noise or wobble at all is bad, it will get much worse at speed. You can also start the engine with the belt off and see if the noise went away. If not, try the other belts. You can take all the belts off and it will still run for a test.
It's kind of overdue for a timing belt change. Even without reaching the number of miles it should be replaced after several years because rubber deteriorates with age. If you were to drive until the timing belt breaks, severe engine damage is likely.
joshml
06-07-2014 04:56 AM
colby_666
18
12-18-2009 05:43 PM
Kenneth Ames
03-20-2007 02:42 PM
se7ensectoolate
05-18-2005 05:53 PM
egthareal
01-24-2005 03:10 PM
Quick Reply: 2002 Honda Civic noise just happened today
