parked car yesterday, wont start today need help today please
Old Dec 6, 2009 | 12:38 PM
colby_666's Avatar
Default parked car yesterday, wont start today need help today please
i was driving my 98 civic with a b18a1 swap, parked it yesterday, went to start the car today and it just keeps turning over but wont start, figured i would ask before i start to check everything saying its freezing out and i have to get it running tonight for work tomorrow, the car turns over fine so the battery is good... any quick help would be great thanks
Old Dec 6, 2009 | 02:44 PM
pull a spark plug wire and see if its getting spark
Old Dec 6, 2009 | 05:06 PM
supersize's Avatar
Sir Banned-a-lot
when my moms probe was doing it, she just gave it some gas when trying to crank it over and it started. try that
Old Dec 6, 2009 | 05:44 PM
^be sure to read his sig before you try that.
And then check for spark and tell us if you hear a low hum from the back seat when you turn the key in the ignition to the place right before it starts.
Old Dec 6, 2009 | 05:54 PM
colby_666's Avatar
checked and had no spark, took off distributer cap and cleaned the points and started right up, really weird saying it has been running good and havent had starting problems at all until this, problems solved for now, the distributer cap and rotor are brand new, like 100 miles on it and is already the points were a little corroded, not alot but more than i would expect from only 100 miles, sounds weird??? i dont really know... but cleaning them fixed it unless it was something else that fixed it but i didnt do anything but check for spark and clean the points
Old Dec 6, 2009 | 06:57 PM
maybe wanna check ur main fuel relay circuit board may wanna resolder the connections
Old Dec 7, 2009 | 01:01 AM
colby_666's Avatar
ok i went to start the car the car this morning, wont start, no spark, ill look into the main relay circuit board thing in the manual and ill check to bouble check to fuel pump is still coming on
Old Dec 7, 2009 | 02:10 AM
if not spark then u may have a bad coil, if its the fuel pump not coming on then it could be the main fuel relay.
Old Dec 7, 2009 | 03:05 AM
colby_666's Avatar
Isn't the coil inside the distributer? Never seen a pic saying what all those sensors in the distributer are
Old Dec 7, 2009 | 12:39 PM
Live_4it's Avatar
how does the starter sound when you crank it? check connections like mentioned, sometimes the terminals on the battery will become oxidized and you'll see blue or green stuff. Sand paper it off or they even make a neat little tool to scrap it off.
