parked car yesterday, wont start today need help today please
Old Dec 7, 2009 | 04:09 PM
colby_666's Avatar
Ok today I took out the coil cause I thought I had another one that was the same but it turned out to be different so I put it back together and the car started and ran find...
I know the starter is good, had that checked while doing the swap not long ago
i previously checked the grounds and cleaned them and the battery posts
so as of right this second the car is running but I'll see if it starts tomorrow morning to get to work, thanks for the help, I still don't know what the problem is, I'm thinking short somewhere or loose wire maybe???
Old Dec 9, 2009 | 02:24 AM
Mad7s's Avatar
Don't know where you're at with all this, but this site is like my 12 step recovery plan for my starting issues. Hope is helps and you get it running.
http://www.tegger.com/hondafaq/start...tml#badigniter
Old Dec 9, 2009 | 07:52 AM
colby_666's Avatar
thanks for the link, ill use that and start checking stuff i guess, well tomorrow ill start checking stuff saying its snowing like crazy today
by the way i went to start the car again this morning and it wouldn't start, it would crank over not not start, after trying to crank it over about 15 times it stuttered a little and then i pushed in the gas and it started right up...
Old Dec 9, 2009 | 08:12 AM
have you checked the main fuel relay?>??
Old Dec 10, 2009 | 02:55 PM
colby_666's Avatar
i just checked this relay, i think its the same one your talking about and its good
http://techauto.awardspace.com/mainrelay.html
so so far i know the main relay is good, starter is good, plugs are new, distributor cap and rotor are new, coil is good, im getting fuel to the fuel rail
but when it doesnt want to start its not getting spark but still getting fuel to the rail...but sometimes it starts after i try to crank it over a couple times and after it is running, if i can keep it running and warm it up it has always started if i shut it off as long as it is still warm
i really need this fixed but im stuck, thanks for all the help, please keep it coming lol
and one more thing that never got mentioned by anyone, the contact points on the distributor cap got corroded after only 100 miles, is that normal? i wouldn't think they would after that short of time... maybe this is a clue to something above my knowledge or maybe nothing but figured i would mention it
Old Dec 10, 2009 | 04:12 PM
have you checked the cps in the dizzy?
Old Dec 10, 2009 | 04:43 PM
colby_666's Avatar
i did about 2 weeks ago, ill go ahead and check that and igniter again tomorrow
Old Dec 10, 2009 | 06:30 PM
also check your fuse box under hood, make sure all the screws that hold the square fuses down are all there and tight.
Old Dec 18, 2009 | 05:43 PM
colby_666's Avatar
ok after checking everything in the dissy and it all testing good, i went to a local garage to see if they had parts i could swap to try to find the problem cause i know the guy that owns the garage and by super luck they had a crv that they were working on that had the same exact problem and as i got there there were just starting the crv and said it was the igniter and thats my problem, and as it turns out the igniter in the b18 dissy is the same as the one in the stock motor that i just swapped out and had it laying around so i saved the $120, thats what the garage just paid for the one they replaced, and the car started right up and been driving good since! thanks for all the help but like i said i tested it and it tested good but was not so thats a good lesson i guess, i hate electronics and even more so when the problem is on and off so it sucks finding the problem
Rolando
13
Nov 20, 2010 02:15 AM
bmelloh
May 16, 2009 08:01 PM
Obligatory
Oct 6, 2007 08:02 PM
gpacheco101
Jan 23, 2007 05:29 PM
gpacheco101
Jan 18, 2007 07:15 PM
