94 civic electrical problems
Old 11-02-2014, 04:06 AM
rustysurfer1505's Avatar
Default 94 civic electrical problems
I recently had my timing belt break on my 94 civic ex. I replaced it along with the water pump and had a valve job done. Car ran great then I started having battery problems. I tested the voltage at the battery and fonud the alternator wasn't charging it. I went and got a new alternator and when I went to put it on, I found that the fuel pump wasn't kicking on and the car wont shift out of park. any ideas of what could cause this? seems coincidental, also this is my first time posting so if I di it wrong let me know. thanks
Old 11-02-2014, 09:44 AM
Always disconnect the battery before you attempt to R&R alternator, or you're going to blow the main fuse. The big output wire on the alternator is live all the time even with the key off.
Old 06-17-2016, 08:17 AM
tz779's Avatar
i think i have blown the "main fuse", which one is that? "Ignition 1" fuse 20, multimeter says its ok, but with key on, no voltage across termiinals. no voltage at alternator either. No interior lights, no door buzzer, nothing.
Help! Thank you !
Robin
fierychick
01-29-2009 11:23 AM
flyer333555
09-02-2007 07:06 PM
gunner671
04-26-2007 12:18 AM
Dr Talon
12-08-2006 12:30 PM
abe_frohman
09-17-2005 08:05 AM
Quick Reply: 94 civic electrical problems
