98 civic dx, starter turns the motor but engine want start
Old 08-05-2012, 02:15 PM
tilyukon's Avatar
Default 98 civic dx, starter turns the motor but engine want start
while driving the car the other day, it of the sudden started to spurt and spit, then the motor shut off, car will crank but want start, i have spark, fuel and compression. what else could it be?
Old 08-05-2012, 06:14 PM
conceptualpolymer's Avatar
How old is the timing belt?
Old 08-06-2012, 03:31 AM
tilyukon's Avatar
I replaced the belt this last Saturday, so I'm totally out of ideals.
Old 08-08-2012, 05:37 AM
Dirty_Dan's Avatar
just because you have spark and fuel doesn't rule out that theres not a problem with the spark or fuel.
are you getting proper fuel pressure, are you getting strong enough spark. is your timing correct. these are all questions you need to ask your self.
From my experience with Honda on matters like these it was almost always a spark issue.
Im not saying that this is your issue but if i where you i would double check everything. if you have a buddy with the same car swap out distributors and see if Yours will start his car or vice versa.
Good luck!
RobTimmerman
10-16-2012 03:16 PM
HootieMcMints
09-19-2011 12:14 AM
AndiSangiovese
06-29-2010 02:01 PM
kheaven86
10-22-2009 11:12 AM
rafamofon
12-04-2007 07:02 PM
Quick Reply: 98 civic dx, starter turns the motor but engine want start
