engine turns, but no start .. Please Help!
Old Oct 21, 2009 | 11:59 AM
kheaven86's Avatar
Default engine turns, but no start .. Please Help!
Hi, my moms 89 Civic LX did not want to start yesterday, so after checking a couple things out, I thought it could be that the starter was bad since the engine didn't even turn. After I replaced that, I attempted to start, but still, no luck. I then thought it would be the battery since it didn't want to start my own car either, so, I replaced that as well .. and still, nothing. So, now, the engine turns and turns but doesn't start. What could the problem be? Maybe the distributor? Thanks in advance for the help!!
Old Oct 21, 2009 | 12:04 PM
check all the cars fuses under hood and under dash
Old Oct 21, 2009 | 12:11 PM
kheaven86's Avatar
all fuses relating to ignition have been checked and they're all good ... anything else I can check? Thanks.
Old Oct 21, 2009 | 12:13 PM
justin07731's Avatar
check to make shure your getting spark at the plugs
Old Oct 21, 2009 | 12:29 PM
kheaven86's Avatar
i believe that to be the reason why the engine won't start .. is there a method to check if I'm getting spark to the plugs? Sorry, I'm not really mechanically savvy .. thanks again!
Old Oct 21, 2009 | 12:51 PM
lol its ok an easy way is to pull the wire and plug out have the plug in the wire and hold the tip if the pluck close to the head and then have some one turn over the car u should be able to c the spack if u have it but be carful not to shock your self hold the wire fron the rubber
Old Oct 21, 2009 | 01:05 PM
import4ever's Avatar
I just fix my wife mitsubishi colt. The car engine turn but does not start. I thought it the battery too. I also thought its the old belts. I replace the belts but its turn but does not start. So I decide to search for the firing sequence on my car. Also, I found the sequence on how or which spark plug cable goes where on the distributor cab. By the way I did replace the Distributor cab and rotor. After I put all the spark plugs cable goes where it suppose to go. I also pull the spark plugs out and see the condition of the plugs. The car start without any problem. Its even run better than before. Here a site you may get more help or just something to know: http://www.2carpros.com/forum/car-wi...art-vt312.html
Old Oct 21, 2009 | 01:41 PM
kheaven86's Avatar
Justin, thanx for the tip, i'll check it out ASAP .. and import4ever, its funny u mention the sequence of the distributor wires to the spark plugs. I have a weird feeling that might have something to do with it cause everytime I turn the key, I hear a loud bang coming from the distributor, or at least i did before I changed the starter .. I'll give both a shot and see what happens .. thanks!!
Old Oct 22, 2009 | 08:27 AM
droopy128's Avatar
if all fail.. check your relay.. it sit next to the hood release latch on the left side, hidden from view.
if you turn your key to 'on' position (don't start it), you will hear a click noise, if not then it your relay, but if you hear the click noise and it working properly, then most likely it's your distributor.
Droopy
Old Oct 22, 2009 | 11:12 AM
kheaven86's Avatar
Hey guys, i wanted to thank all of u for helping me out. Basically, the battery was the original problem, but I made the dumb mistake of messing with the distributor wires, throwing off the firing sequence in the process, which resulted in the engine turning but not starting. I googled the firing sequence, put the wires in the correct order, and boom, engine starts and runs perfect again! Once again, thanks for the help!!!
tilyukon
Aug 8, 2012 05:37 AM
HootieMcMints
Sep 19, 2011 12:14 AM
wantacivicwagon
18
Jul 25, 2011 02:18 PM
Liddy-b
Jun 23, 2011 10:44 AM
rafamofon
Dec 4, 2007 07:02 PM
