Alarm going of randamley
hello i brought a Honda civic 1.6i ls 1996 my battery dies the other day and since this day my alarm has been going off randomly also on the read door there is a sensor to let you know that the door is shut some times this flickers the alarm is standard
the other thing is the abs light comes on then comes off rampantly
what do you think could be the problem thanks
Check the door switch, if it's flakey that will trigger the alarm because it sees a wrong signal from the switch and thinks that someone has opened the door.
Check for bad connections at the battery. You also could disconnect the battery for several minutes (with the key off) then reconnect it to reset everything.
This problem is now sorted!! Put a spacer on door thanks for the help!!!!!
NOW ways to stop the door lock from freezing because when I brought the car I only got one key it didn't come with the keyless entry fob for alarm???
tooquick
05-26-2012 09:17 AM
erikmelo
09-29-2009 08:18 AM
BruceK
08-04-2007 09:15 AM
