code 41, O2 sensor fixed, then code 67 ???
Old 01-12-2005, 07:44 PM
Black Magician Hiro's Avatar
Default code 41, O2 sensor fixed, then code 67 ???
Primary heated O2 sensor heater circuit fault ( sensor 1 ) was replaced, code 41 vanished and followed by code 67, Catalyst system efficiency below threshold.
Honda Dealer would replace a cat for $1,200 plus labor, shop supplies, etc and taxes.
High flow cat or a resonator does not come with O2 sensor fittings.
Has anyone installed a test pipe on OBD-II CIvics without hooking up sencondary O2 sensor?
2000 Honda Civic EX
Old 01-12-2005, 08:52 PM
sacicons's Avatar
Default RE: code 41, O2 sensor fixed, then code 67 ???
dont do a test pipe. itll trip CELs all the time. also, you can find a high flow cat for WAY less than the stock one.
Old 01-15-2005, 08:47 PM
Catco made a highflow catalytic converter PN# 4839 for Civic Si.
Do you know of anyone using Catco highflow converter or othr brand with a good result, perfromance without check engine light on?
general23cmp
12-20-2008 10:43 PM
SiX
03-12-2008 12:14 PM
Hola
09-17-2007 05:24 AM
Act of God
01-20-2007 04:53 PM
Quick Reply: code 41, O2 sensor fixed, then code 67 ???
