Sponsored by:
Sponsored by:
Front Wheel Bearing replacement issues
Old 12-27-2006, 03:38 PM
beloveddoll's Avatar
Default Front Wheel Bearing replacement issues
Hi All -
I am pretty sure I have a messed up wheel bearing in one of my front tires. We have replaced a wheel bearing in a back tire before, but the front tire's mechanics are different and a bit more daunting. I have a 2000 Honda Civic and from reading the repair manual, I can only assume that I must remove the hub, then have a professional hydraulic press the bearings for me. I know there is a bit more work than that, but I have my dad who understands cars helping me out. All the technical bits are his department!
My main problem right now is that I can't tell what side the bearing is bad on! There is a distinct rotation noise when I turn left, but I don't know if that means the left-front bearing is rubbing harder due to pressure, or if the right-front one's lack of pressure during the turn is causing the noise to increase in volume.
Any help in a diagnosis?
Help a poor, confused girl out!
Thanks,
Amy
darkangrydragon
04-03-2012 01:37 PM
crimsonnblue
05-23-2007 08:47 AM
kevalmiller
02-10-2007 07:38 AM
EG 8
01-15-2007 10:19 AM
supradupra
11-09-2006 10:13 AM
Quick Reply: Front Wheel Bearing replacement issues
