Gremlin, wont start
Old 10-30-2012, 07:42 AM
David_S's Avatar
Default Gremlin, wont start
When I turn on the key the turn signal indicators and the brights indicator come on. When this happens the engine won't get any spark.
Old 10-30-2012, 07:57 AM
It is better to keep all this stuff related to the same problem of not starting in one thread.
Strange interaction between seemingly unrelated electrical stuff is almost always a bad ground. Turn key on and measure with a voltmeter to confirm the car body and the engine block are both near zero volts relative to the battery (-) post. Check that the ECU ground wires on the thermostat housing are secure and also zero volts to battery (-). The cluster has a ground somewhere behind the dash but I'm not sure if losing it would cause no spark.
You also said the previous owner had added some new wires?
Old 10-30-2012, 10:22 AM
David_S's Avatar
They had bypassed the wiring harness for the starter wire. Hence when I hooked up the wiring harness correctly it wouldn't start.
I just wired all the ground wires to the starter, block and where the harness connects to the thermo housing.
When I turn on the headlights I can hear the fuel pump engage and the dash lights come on for the seatbelt door etc....
I think that this is some kind of cross wiring between the lighting system and the ignition system.
Old 10-30-2012, 12:41 PM
It sounds like you don't have the body grounded. The big wire from battery (-) should bolt to the body first then go on to the transmission / engine assembly.
Old 10-31-2012, 09:21 AM
David_S's Avatar
Thanks man thats what it turned out to be. Button down a few more items and it will be my daily driver from then on.
BombSquad91
01-21-2013 05:01 PM
fuelsmech29
11-14-2010 10:04 PM
Locke
09-10-2010 08:41 AM
bmelloh
05-16-2009 08:01 PM
ccwhit7
10-31-2008 03:43 AM
Quick Reply: Gremlin, wont start
