Idling Problems
Idling Problems
I have a 1995 civic ex and i just put another motor in it and i used the old throttle body off of my old motor and i have also cahgne the idle valve sensor and i still have a idling problem it wants to go from a 1000 rpm and jump up to 2500 rpm on its own any suggestions? could it be any other sensors
Trust has some good suggestions that you should look into.
Is the CEL ON?
Also, the throttle body has two holes/ports, which lead to either the IACV/EACV or the fast idle valve. When the engine is warm, use your finger to cover the hole/port in the throttle body leading to the fast idle valve. If you feel suction and blocking the port returns the idle to normal, then cleaning the fast idle valve may fix the problem.
Is the CEL ON?
RedSi
02-21-2007 11:41 AM
