No Cruise...94 Del Sol
Old 06-24-2012, 05:50 PM
shinyside's Avatar
Default No Cruise...94 Del Sol
Hey guys, Matt here 1994 Honda Del Sol Si.
For any Honda Techs out there I have a factory cruise control system on the car but it does not work.
If I'm going down the highway, and I press the switch on the dash to engage it the intrument panel "cruise control" light does not illuminate. If I try to set it it will not set.
So my questions are...do you think the switch itself is bad or perhaps the whole unit itself??
Is there a relay for it?? I've checked all the fuses and have yet to see any blown, but I have not checked the larger fuse blocks under the hood as I am unsure if they corralate to the cruise system.
Any and all help would be appreciated as I am completely new to Hondas, and wiring has never been my specialty.
Thanks in advance!!
Old 06-25-2012, 11:43 AM
The bulb in the master switch button is commonly burnt out after years of leaving it on all the time. Check the rubber pads for the switches on the brake and clutch pedals. If it thinks that a pedal is pressed, the cruise will not engage. Also check that the vacuum line is connected to the cruise actuator under the hood.
Old 06-26-2012, 04:53 AM
shinyside's Avatar
Cool thanks for the heads up!! I'll give that a check this weekend I appreciate the reply.
Old 07-01-2012, 11:32 AM
shinyside's Avatar
Well got the cruise fixed :-). There were no grommets in place, the genius before me taped pennies over the hole where the grommets were supposed to be!!! WOW
Also, the main harness connector was all hacked up and I had to cut and splice the pigtail. So either the grommets or the wiring or both, but either way she's back in action
livejamie
08-12-2011 06:53 AM
Faramire
08-01-2010 11:42 AM
dmsteele92831
07-23-2007 11:10 AM
SMooTHn
12-01-2006 02:03 PM
sol2k
05-04-2004 09:41 PM
Quick Reply: No Cruise...94 Del Sol
