Over heating
Old 11-20-2012, 02:06 PM
Bailey19d's Avatar
Default Over heating
OK guys, I'm new here so sorry if I'm posting in the wrong spot. I just got a 1995 Honda Civic DX, or what I was told. I was also told it was a VTec how ever it does not say any where on the car that it is a VTec. Starting off, I got the car, drove it and it was ok. I was told it had an over heating problem but I would be able to drive it daily. That was not true, I left from buying it and over heated about 5 miles down the road. Spitting coolant from the over flow. I got it back home and then replaced the over flow and noticed that the fans were not coming on when I was over heating. I got the fans working. I also noticed white smoke coming from the exhaust. I'm assuming that is due to a blown head gasket. What I'm needing to know is what can I do, how hard is it to replace the head gasket. I have already got the haynes repair manual. Just needing some inside help here. I really know nothing about these cars and I have been out of a shop for a long time now. Thank you for your help.
Old 11-21-2012, 05:44 AM
Bailey19d's Avatar
ok never mind, there was a post right below mine that had the same problem..Should have read a little
Old 11-21-2012, 06:17 AM
HaulinAzz's Avatar
Banned
If it's the stock engine then it's not vtec. Sounds like someone took you to the cleaners.
Old 11-21-2012, 06:43 AM
Fans not coming on sounds like a simply fix. It usually is, however, if it is let go, or unnoticed it can ruin everything.
I am sure there are a few DIY guides. For a first timer, plan to spend most of a weekend on this. Get yourself a torque wrench, too. You may want to check the head for levelness, too.
You could also just pull the entire motor out of the car and replace it.
seppy
04-23-2007 06:37 AM
dudes96
04-17-2007 03:49 AM
stylus
06-11-2006 07:46 PM
mugen1
06-07-2006 01:54 PM
jad1217
12-07-2005 08:56 PM
Quick Reply: Over heating
